2006 Dakota
Old Mar 14, 2021 | 08:49 AM
Chuck Jongbloedt's Avatar
Chuck Jongbloedt
Unhappy 2006 Dakota
This has happened before. Comes and goes. ABS and brake light on and speedometer stays on 10 mph. Speedometer will go to 0 when turned off. New wiring harness and ABS. There is no check engine light. Last time in the shop for this I was told there is an issue with the dakota with dampness in fuse block. No remedy was giving. Please help
Old Mar 14, 2021 | 09:23 AM
dakotaff's Avatar
dakotaff
You need to connect an advanced code reader to find out what is causing the ABS light. One that reads (and clears) ABS/SRS codes, something like
<b>this one</b> this one
Otherwise you're just guessing and throwing parts at it. Find a real mechanic who can read the code, and repair the issue, not one who says the fuse box is damp. There is no Dakota issue with dampness anything.
Welcome aboard.
Old Mar 14, 2021 | 09:45 AM
Chuck Jongbloedt
Originally Posted by dakotaff
You need to connect an advanced code reader to find out what is causing the ABS light. One that reads (and clears) ABS/SRS codes, something like this one.
Welcome aboard.
I want to thank you for your response. I will take your advise
Chuck
