Stalling with no codes.
Old Oct 6, 2021 | 11:36 AM
RthrDent's Avatar
RthrDent
Default Stalling with no codes.
Hi y'all.
I'm hoping someone can help me out with this head scratcher. Five years ago I developed this random stall with no codes. I paid for an online Dodge tech who told me the only thing that can cause this is a bad PCM. I replaced the pcm and problem solved. Fast forward to now and I have the same issue but this time a new PCM didn't fix it. The best way to describe what's happening is to imagine a non OBD vehicle with say a bad connection at the coil. It's like the ignition just dies. The truck will always restart, sometimes on the first try and sometimes it takes 5 or 6 attempts before it will start and stay running. There is no hard pattern to the stalls but it seems to do it more often when coming to a stop or at tip-in. I've mostly ruled out a fuel issue, new fuel pump and switched relays. Also replaced IAC and TPS. I'm thinking it's a bad connection somewhere maybe. Has anyone ever solved this issue? Truck is an 05 quad SLT, 4.7 and 6 speed manual. Thank you!
Old Oct 6, 2021 | 05:09 PM
pilotsmack's Avatar
pilotsmack
Quite possibly either a bad connection on your battery, or a bad ground somewhere.
Old Oct 7, 2021 | 01:30 AM
KristenG's Avatar
KristenG
I had that kind of problem when my battery was going bad. It seemed to stall at every stop sign unless I kept my foot on the gas and kept the RPM's up. It all disappeared with a new battery. This may not even be related to your problem. If your battery is old it is worth a look.
Old Oct 17, 2021 | 12:47 PM
hidden1's Avatar
hidden1
Wont hurt to check grounds an the ASR -auto shutdown relay -switch out .with same.Also fuel Injector test is another one worth checking .
Did you use oem sensors? These trucks hate off market brands !
