Trans temp fluid sensor !
Old Dec 12, 2021 | 01:39 PM
comar05's Avatar
comar05
Default Trans temp fluid sensor !
Has anyone replaced the transmission fluid temp sensor?
I can’t seem to find a place that sells it. Trans is starting to jump so I’m not driving it until it’s replaced.
Old Dec 12, 2021 | 11:23 PM
dakotaff's Avatar
dakotaff
I could be wrong, but I think it's part of a solenoid pack, and not a seperate sensor.
Any codes?
Old Dec 14, 2021 | 11:42 AM
pilotsmack's Avatar
pilotsmack
Yup, the temp sensor is a thermister that is integrated into the solenoid pack, so you gotta replace it all as one unit.
Monitored the temp while driving with live data from your OBD? Random temp spikes (say, from 80C to 200C, back to 80C in about 5-10seconds) are typically caused by either aeration of the fluid, or metal in the fluid. So my first question would be, how is your fluid level? Checked it the proper way, all hot and on a level surface, in Neutral after going through all the gears?
If the level is good, it points to metal in the fluid. When was the last time you serviced the trans?
