No right rear brake light or turn signal
Hi all,
Apologies if this has been covered, any help is appreciated. I suddenly lost my right rear turn signal and brake light. Tried changing the bulb, no dice. Swapped with the left socket, still no good. Then I thought it might be ground but the running light works so it's not that. Then made sure my bulbs are good, they are. I thought it might be the signal wire that was open (white/orange) but I have continuity from the socket to where the harness plugs into the tipm under the fuse box. Before I go changing the tipm or the fcm, is there anything I missed? Can I swap these parts with ones pulled from a wrecker? TIA!
