2008 Dakota TRX4 Wiring Diagram
Anyone know where I can get one? Specifically looking for the transfer case motor. Mine was working intermittently and giving a C140B code of low return signal voltage. I have seen this could be the TPIM, but upon pulling the fuse block housing out, I see a few chaffed wires and need to figure out if they are from the transfer case motor or something else. So I guess I really a more expansive diagram is they aren't part of the transfer case motor.
Well, I would still like to get one but have the transfer case issue fixed..
Decided to crawl back up under the vehicle again to check wiring and noticed that after I pulled the connector, one of the wires and pin had backed out of the connector. Finally got it seated back and everything is working great now..
Still have the chaffed wires to deal with..
Agreed.. But I think it was an intermittent connection on that same wire which made me buy a whole new transfer case motor which I already installed.. Will probably just leave it at this point and keep the old one as a spare.
You used to be able to buy them from Mopar at techauthority.com. But, they seem to have changed the webpage and locked it out with a password. Other than that, you'd have to search online. I think they were still making paper copies of the service and wiring manuals in 2008. So, you can probably find some for sale.
