2006 laramie 4x4
Old May 7, 2024 | 07:47 PM
mrtweaver's Avatar
mrtweaver
Default 2006 laramie 4x4
I have 2006 dodge dakota laramie crew cab 4x4 i am told it has the short bed. And the reason i am posting is id like to know what all years, makes and models are interchangeable when it comes to the bed. Will only 3rd gen dodge fit? What years? Any other makes or models that will fit?
TIA
Old May 8, 2024 | 07:33 AM
Yes. 3rd gen 2005-2011
Old May 8, 2024 | 09:00 PM
Blacknights's Avatar
Blacknights
If you're in a pinch, I believe the Mitsubishi Raider beds were identical as well.
Old Jun 12, 2024 | 07:46 AM
mrtweaver's Avatar
mrtweaver
Thank you all that posted, two weeks ago i went to baltimore md to a you pull it junk yard, none of the dakotas had a bed on them, but on a pinch i looked for the Mitsubishi as mentioned here, found one the exact color and everything, well maybe just a hint shade different than the cab but close enough and it caused the truck to pass inspection, the other bed was gut rotted. But again much thanks to all.
Old Jun 12, 2024 | 03:58 PM
Blacknights
I'll take a victory for the forums! That's what's up! Good enough to pass an inspection, wahoo!
