Which AC gasket?
Old Oct 1, 2025 | 05:43 PM
jsmi5391's Avatar
jsmi5391
Default Which AC gasket?
I have an 06 Dodge Dakota and I am changing all the AC components, except the evap coil. I have a generic set of AC gaskets and O rings here. The original AC lines to the compressor, condensor, and accumulator used the dark all metal crush washers. The kit I received has flat shiny metal washers with the green rubber seals. These seem like an upgrade, but they are quite a bit thicker than the original metal crush gaskets and I worry about getting a good seal. Does anyone have experience with these gaskets? Or is it better to get more metal crush gaskets.
Note, I tried to put a picture of the gasket seals here, but it's not letting my upload images.
