Jet chip install
Old May 18, 2006 | 03:01 AM
  #21
luvmydak's Avatar
luvmydak
Default RE: Jet chip install
Reply to jersharp. Stage II NOT recommended without 180 thermostat which at this point in time is not available for 3.7L. I would have preferred the StageII in my '05 Dak but had to settle for the StageI. Suggestions have been made about drilling 3 holes in a triangular pattern in the 195 to supposedly act as a 180 but that just does not set well with me. I personally think it's a bad idea.
Old May 18, 2006 | 03:54 AM
  #22
maxmax's Avatar
maxmax
Check the standard part no for the replacement thermostat for both the 3.7 an 4.7. I believe they are the same thermostat. If they are then the NAPA 180 degree Superstat part no. 530080 which does work in the 4.7 will also work in the 3.7.
Old May 10, 2008 | 08:40 PM
  #23
bobbi71's Avatar
bobbi71
Do anyone of you know, where the ECM is, in a Durango 4.7L 2006. According to the instruction (I want to install stage 1 Jet chip), the ECM is on the passenger side, in the engine room, next to the air intake. But there is the battery? I can´t see under it. And the pic in the instructions that came with it, are definitely not from that vehicle.
Does any of you know this?
With thanks in advance, Birgir Johannesson.
Old May 11, 2008 | 12:05 AM
  #24
tuffone20's Avatar
tuffone20
I've been thinking about getting a stage 2 one, but every one keeps saying to run 93 or better gas here in AZ I only see 91?
Old May 11, 2008 | 06:03 PM
  #25
superdak05's Avatar
superdak05
remember that you have the 4.7 h.o. motor so you will need the stage 2 chip for that motor, not the regular 4.7 91 octane will work fine for you. you wont see much gains if you use 89 or lower
Old May 14, 2008 | 09:37 PM
  #26
Altair's Avatar
Altair
Dak attack!
ORIGINAL: bobbi71
You will probably have much better luck getting an answer if you ask in the Durango section .
Old May 15, 2008 | 10:56 PM
  #27
DD064x4QC's Avatar
DD064x4QC
so for a regular 4.7 a stage one is ok? and can you still run regular gas with the chip and see results? just wondering about this chip cuz i'm looking for a little improvement on mpg's and a little more horsepower.
Old May 16, 2008 | 07:23 AM
  #29
rick4dak's Avatar
rick4dak
My Stage 1 didn't help or hurt mileage enough to measure but it adds enough power to feel. I tried 91 octane but 87 performs just as well under most circumstances. When I tow, I use 89 octane to help prevent detonation.
