05 dakota broken mirror
Old Feb 28, 2006 | 01:28 PM
kenny y's Avatar
kenny y
Default 05 dakota broken mirror
i have a 05 qc, with a brooken left side mirror. can i just buy the glass part?, or how much of it do i need. how much trouble is it to change...............help...thanks
Old Feb 28, 2006 | 04:30 PM
28this's Avatar
28this
Default RE: 05 dakota broken mirror
Here is one way on eBay. Looke like it would be extremely easy. If you change whole housing also, it's not that hard either. Remove door panel, then inside you'll find three nuts holding housing on. Remove and slide out. Disconnect wires if powered mirror. Install opposite.
Old Mar 1, 2006 | 06:21 AM
snobrdrdan's Avatar
snobrdrdan
Yeah like 28this said....it's easier (& probably cheaper) to just replace the whole mirror with a used one instead of replacing the glass only
Replacing the mirror is super easy though!
On my '04 Dakota (when I had it)...I swapped from the big (towing) mirrors to the little mirrors in like 5 minutes....SUPER SUPER easy to do!
Old Mar 1, 2006 | 10:00 AM
sdsdsd's Avatar
sdsdsd
Dodge sells the glass replacement it has double back attachment tape easy to change.
Old Mar 2, 2006 | 01:21 PM
kenny y's Avatar
kenny y
sdsdsd, cant find replacement glass mirror, dodge dealer says buy the whole thing.please advise .............kenny y
Old Mar 2, 2006 | 06:19 PM
28this's Avatar
28this
What do you mean no replacement mirror only, without buying the whole assembly? I gave you an ebay link in a earlier post that had one for your truck. Look at my last post before this one and click on the word eBay.
