Stereo setup?? Sub-woofer placement???
Old Mar 21, 2006 | 12:00 AM
pino_55's Avatar
pino_55
Default Stereo setup?? Sub-woofer placement???
Hey everyone I'm having a issue with the lack of space in my quad cab to install a sub. I already have aftermarket headunit, and changed the fronts. I had a few ideas, but am wondering what some of you guys have as setups? (especially what you did to add more bass)
Old Mar 22, 2006 | 02:28 AM
PEPPERHEAD's Avatar
PEPPERHEAD
Default RE: Stereo setup?? Sub-woofer placement???
Sub options are kind of lacking in these trucks. An MTX Thunderform behind the seat. Or a custom box between the center console and rear seats. A 10" sub will be the max with a max of about .6cf for the box. Did you have the basic radio or the Infinity system? If you had the infinity system did use the OEM amp or bypass it. If you used the OEM amp how did you wire it to the new HU? Good luck with the sub selection.
TASTE THE HEAT AND ENJOY THE PAIN
Old Mar 22, 2006 | 03:52 AM
Frenchy's Avatar
Frenchy
**** it, tear out the rear seat... who needs passengers anyways?!
Cut a hole in the wall and in the box, and weld a box in there.
Then replace the seat. That's what I'm doing in my friends 94 S-10. Making a box inside the welded area tho. :-) Should be one HELLOVA project.
