Ride Height
Old May 2, 2006 | 11:59 AM
Mopower3.7's Avatar
Mopower3.7
Default Ride Height
Ok i have a question, i own a 20005 dakota 3.7 4x4. I want to know why this truck seems so low. Does it have torsion bars that can be tighten for a raised front end????Whats the biggest tire you can run stock?? Does any one know if the trx-4 pacage can be installed on my 05?? Info on the packag??
Old May 2, 2006 | 08:57 PM
Dak_in_Black's Avatar
Dak_in_Black
Default RE: Ride Height
The 05s do not have torsion bars, coil over if I am not mistaken.
I believe there is a leveling kit available, but no lift kit out yet.
Can't help with the other questions.
Old May 2, 2006 | 09:54 PM
snobrdrdan's Avatar
snobrdrdan
They went with a "lower" Dakota (4x2 & 4x4's have the same ride height) so that it has a more car like/smooth ride......which it does compared to previous generations of the Dakota.
Yeah you can put bigger tires/wheels on your truck.....the speedometer will read incorrectly though (it'll be off). You'd have to go to the dealer to get it programmed in (the new tire size) or wait for a handheld "tuner" to come out to change it.
TRX package will only give you a VERY VERY small increase in height (it's supposedly a 1/2 or 1 inch lift).....the cost would be very ridiculous I would think since you'd have to buy it from Mopar.
Just wait for a full lift kit, or buy the front leveling kit which raises the front up 2" for a level, higher look. It's like $80 or $100 for that front leveling kit....well worth it for the 4x4 guys. (I have a 4x2)
Old May 2, 2006 | 09:58 PM
snobrdrdan's Avatar
snobrdrdan
By the way...it's a simple install for that 2" front leveling kit too
It was $79 for that kit.....and I guess it's been discontinued after I did a search....if you can find one here's before & after pics (courtesy of Dakotahub)
Says it's been discontinued here: http://performancelifts.com/cgi-bin/cart/PER61062.html
Before:
After:
