Rear upgrade 3.55 to 3.9 or 4.1 a performance benefit?
Old May 8, 2006 | 07:42 PM
luvmydak's Avatar
luvmydak
Default Rear upgrade 3.55 to 3.9 or 4.1 a performance benefit?
Will upgrading the 3.55 rear to 3.9 or 4.1 result in a performance gain in a '05 3.7? Does it matter that the truck has a selectable Tow/Haul feature? How much will this change out cost? Need a reliable response not a guess or maybe.
Old May 14, 2006 | 05:35 AM
snobrdrdan's Avatar
snobrdrdan
Default RE: Rear upgrade 3.55 to 3.9 or 4.1 a performance benefit?
I went from 3.55 to 4.10 gears, BUT I have the 4.7 V-8
I paid $180 for the 4.10 Motive Gears
I also bought a Dana Trac-Lok LSD for $260 and had that installed too
It was $300 for the labor. They put in the LSD for free though since the stock differential has to come out anyways when you change the gears. I recommend having a shop do it though......the shop that did mine was specifically a Ring & Pinion shop.
Overall...I'm happy with it. Gas mileage hasn't really changed & it takes off a lot quicker now & responds better on the freeway.
Old May 15, 2006 | 05:11 PM
bbcdon's Avatar
bbcdon
Did it affect your speedo, or did you change the codes in the factory ecm. They told me anything above 3.91 affects the abs, but they didn't impress me at the dealership. Have you had any electronic issues with your computer? Thanks, Don.
Old May 15, 2006 | 08:04 PM
28this's Avatar
28this
Is your Dak a 4x4 or a 4x2. If 4x4, you'll have to change the ring and pinion in the front also to match.
Old May 16, 2006 | 04:39 PM
snobrdrdan's Avatar
snobrdrdan
Well according to a couple guys on Dakota-Durango that did the gear swap......the speedo is read off the tranny & the ring gear or something like that and it doesn't need to be changed in the computer
So no I didn't have them change the settings in the computer & like I said in the other post....my truck runs perfect. Just changed the gears & added a LSD, and the speedo reads accurate
Here's a post from Dakota-Durango:
http://www.dakota-durango.com/forum/...ad.php?t=14555
