Rear Swap possible?
Old May 15, 2006 | 06:46 AM
Frenchy's Avatar
Frenchy
Default Rear Swap possible?
So a friend and I have been talking, I was talking about doing a rear disc conversion for braking. And instead of doing all that work he asked me what vehicle from Daim/Chry would match up similarly with the Dakota, the first that came to mind was the new Durango. Now that vehicle has rear discs, and he suggested just swappin the rear ends out. I'm not too sure what he meant, but sounded like a good idea. The kid knows his ****, but isn't too familiar with Dodge. He's a huge Chevy fan. Oh well.
Does anyone know what I am talking about? And if so, if I found say a totalled 05+ Durango, would it be possible to switch the rear ends out?
Thanks all.
Old May 15, 2006 | 01:02 PM
ptschett's Avatar
ptschett
Default RE: Rear Swap possible?
The Durango has a wider track than the Dakota (about 3" IIRC). I'm not sure it'd work too well.
Old May 15, 2006 | 01:12 PM
Frenchy's Avatar
Frenchy
REally, well **** on that idea then. Thanks
Old May 15, 2006 | 01:14 PM
superdak05's Avatar
superdak05
might not be a good idea. durangos set up alittle diff. then ours. also is his truck 2 or 4 wheel if 4 wheel you might want to check gears before pulling rear ends out of other vech. give ssbc a call they have every type of disc brake conversion. if not build your own. probably run ya some coin with braided hoses and fitting
stainless steel brake conversion
Old May 16, 2006 | 04:40 AM
FONTANA MOTORSPORTS's Avatar
FONTANA MOTORSPORTS
get the calipers and brackets (also the parking brake ***) from a 2002-present 1500 ram, you will need either new axles(moser can make them..about 250.00 a pair) or have the ram ones cut and resplined.....but as i remember reading somewere , the dakota axle shafts will/should work with the ram brakes...
Old May 16, 2006 | 06:03 AM
Frenchy's Avatar
Frenchy
Hey Rory, thanks for that info, but could you take a look into more for me? I am REALLY planning on doing this soon.... I'm gonna eventually need better braking if I end up going the route I wanna go. :-)
Thanks buddy!
Old May 16, 2006 | 04:47 PM
snobrdrdan's Avatar
snobrdrdan
Your other option could be to find a rear end from a 2004 Dakota.....I know that they came with disc brakes
2003 might have too, but I definitely know that my 2004 had the rear disc brakes on them.......and the rear end might still be the same...so that might be a simpler swap for you
Old May 17, 2006 | 01:58 PM
FONTANA MOTORSPORTS
remember the pre 05 dakotas have 6 lug pattern.
Old May 17, 2006 | 04:27 PM
snobrdrdan's Avatar
snobrdrdan
DO'OH!!!!!
Totally forgot about that!
Well.....you'd just have to have two different sets of wheels in the front & rear then....lol...just kidding
Maybe you could just get the rear disc brake hardware off an '04 Dakota????
Old May 28, 2006 | 07:11 PM
xx1479's Avatar
xx1479
It seems like the best route for this is to go with an 02-up ram. they have 4 whell disc brakes and the 5x5.5 bolt pattern. not sure what else this all entails cause im no mr. goodwrench. anybody know what else a drum to disc conversion takes? any checklists out there?
