roller rockers
Old May 26, 2006 | 02:28 PM
white26golf's Avatar
white26golf
Default roller rockers
hey, i have been doing some research on roller rockers. it seems to me that getting 1.7:1 rockers are a good investment in HP and engine life. My question is that our trucks have hydraulic end-pivot roller rockers, what exactly are these, how do they work and can i find a compatible replacement with regular aftermarket 1.7 rockers? maybe one of you guys can shine some light for me.
Old May 26, 2006 | 07:02 PM
superdak05's Avatar
superdak05
Default RE: roller rockers
krc performance sells them. i am saving up a little more cash cause i am interested in the 212 dual camshaft kit. should knock at least 4 seconds off of stock cams.
Old May 27, 2006 | 02:27 AM
Frenchy's Avatar
Frenchy
What exactly are roller rockers?
Pardon my ignorance.
Old May 27, 2006 | 01:23 PM
white26golf
The orange things in the picture are roller rockers. You have two per cylinder, one for each valve ( exhaust and intake valve on each cylinder). They are called roller rockers, because on the side that hits the valve there is a roller, OEM rockers are usually just cast, which are heavier and do not have rollers which means more friction. I do not know the ratio in our truck, but lyou usually see aftermarket ones from 1.6:1 and 1.7:1. The higher the ratio, the better. They make your truck think that you have a bigger camshaft, which = more power. Hope I didn't forget anything, but i am sure someone will fill in the blanks if I did.
[IMG]local://upfiles/31693/4EE27643FCB74E64B710B076057CD851.jpg[/IMG]
Old May 27, 2006 | 07:52 PM
rodslinger's Avatar
rodslinger
I don't think you are going to find roller rockers for your OHC 3.7 V6. There may be someone out there with modified followers though.
Old May 27, 2006 | 08:32 PM
white26golf
Yeah, I saw a picture of what I think are hydraulic end-pivot roller rockers. They did not look like an easy roller rocker replacement. I don't know much about internal engine parts or how everything works. I just do a lot of reseach and make sure I have more than just one resource to be sure that I am getting the right info. Maybe you can inform me as to what followers are and how they will benefit my truck.
Old May 27, 2006 | 09:24 PM
Frenchy's Avatar
Frenchy
Where would I locate said roller rockers for my 4.7L, and how would one go about installing these? Have a shop do it? Or could a person do this himself?
Old May 27, 2006 | 09:36 PM
white26golf
If they make them for our trucks, they are pretty easy to install. They are pretty simple bolt ons. Just Google Roller rocker install.
