Startup noise?
Old Dec 1, 2006 | 06:12 PM
  #91
trucky's Avatar
trucky
Default RE: Startup noise?
ETX lets show some respect for the moderators. and theres no reason you and graythang need to be at each others throats, we are all more or less in the same boat. CALM DOWN. no need to aim comments at one person...your both good guys, it just seems like you two need separated sometimes. anyways, now that im done being mother hen, rattle those dodge people until they check out your truck for free. and dont give up when they send u on wild goose chases and as some one so plainly put it 'dance around' you
Old Dec 2, 2006 | 12:10 PM
  #92
Dakota Chris's Avatar
Dakota Chris
Hi guys,
just wondering if there are any 3.7's out there that have the same problem? They are technically identical just with two cylinders less. I also wanted to add my 2 cents regarding oil. Some motors can't handle synthetic oil well. While it is supposed to flow better and reach parts faster due to the flow characteristics it is tow thin for some motors or better oil pumps and instead of improving oil flow, you starving you engine at startup.
Dakota Chris
Old Feb 20, 2007 | 06:35 PM
  #93
Dyess5's Avatar
Dyess5
I have an 03 Ram with a 4.7 and I am having the same problem. My truck is at the dealer right now and you just described my situation. They are claiming it is normal, but we all agree it is not. I took the service guy out and he agreed it was pinging and then told Dodge that he could not replicate the "situation" . What ended up being the problem? / "situation" on yours? How do those hemi's run ?? Thank You for the help.
Old Mar 26, 2007 | 07:22 PM
  #94
mark_pruett's Avatar
mark_pruett
Well... finally got around to taking my Dakota in- now that it's warmer outside, the ticking is back.
The guy at the dealership says what's causing my noise is the purge solenoid;apparently they click pretty loudly sometimes.
Does this sound reasonable?
Old Mar 26, 2007 | 09:21 PM
  #95
luvmydak's Avatar
luvmydak
I have a '05 3.7 v6 going past two years now and have never had this "ticking" in either warm weather or cold. Does not sound like something normal to me. I don't buy this "purge solenoid" explanation. Is this something that is happening with the 4.7?
Old Mar 27, 2007 | 09:21 AM
  #96
graythang's Avatar
graythang
I will say this once again! It’s the valve lash adjusters on the right side. There are no lifters or push rods. It’s an overhead cam engine. Both the 4.7 & 3.7 are the same with two less cylinders. I have been through this mess for a year. It was much of what cost DCX a buyback of Gray I. They can't seem to correct the situation at all no mater what they do in the shop to the engines. It might be a milling problem or something not designedor built right from the get go. The 08s are said to have redesigned valve lash adjuster. Hummm. That may be their fix for this problem. By the way Gray I is still parked at the dealer in the back very lonely looking. It is said its going to auction. Make my dealer an offer for her. I bet they will let it go in the teens. 06 4.7 HO TRX4 loadedwith 15k in like new condition with a bunch of crap wrong with it.
Old Mar 27, 2007 | 08:48 PM
  #97
06Dak3.7's Avatar
06Dak3.7
I just read through thisthread. My '06 Dakota with the3.7L engine has the exact problem. I took it in to the dealership this morning for the second time. The first time it was in, I got the "It's normal"and"It's the purge solenoid" comments. This time, I told them that I didn't want to hear that any long, and I want itfixed. In addition, I told them that if it is the solenoid then replace it. With only 6500 miles on the odo. and dealer oil changes every three months, I shouldn't be hearing anything. I doubt this will get resolved, and I will probably end up buying a new or newer vehicle. After being a life long GM owner, I finally tried a different brand, and I am completely dissatisfied. Oh well, live and learn.
Old Mar 28, 2007 | 10:16 PM
  #99
Dusty's Avatar
Dusty
Well my truck just started doing this two mornings in a row now. I suppose I should remove my modifications before I go scream for warranty work.
Old Mar 28, 2007 | 11:02 PM
  #100
graythang's Avatar
graythang
They won’t be able to fix it. I have not read one success story on a repair for the start up chatter. Some guys in other forums had their engines torn apart several time with the noise gone for a shot time than its back. I has to be a design and build defect with no resolve. I guy I use to work with had a 04 Silverado V8 (don't know the size) and it would do the same thing and of course he was told by Chevy it is normal. It’s a role of the dice playing with your hard-earned money on what you receive after the deal. I waiting for my replacement Dak to start making the noise. It took about two months on the first Dak.
