Stereo in my 05DAK
Old Nov 15, 2006 | 10:31 PM
Jaybird's Avatar
Jaybird
Default Stereo in my 05DAK
Hi guys, I've got some really stupid stereo questions for ya. I don't know too much about this so please don't beat me up for asking. I have an Alpine MRP-F306 flex 2/3/4 channel amp in my garage collecting dust. When I do my stereo, I am going to put an 8" sub under each rear seat, and replace the factory door speakers.
So here it is; Can I use my Alpine amp for the door speakers and a seperate amp for the subs? Or should I just sell the alpine and go with one amp for the whole system. If I sell this amp, how much is worth? Anybody out there want it?
Old Nov 15, 2006 | 10:38 PM
superdak05's Avatar
superdak05
Default RE: Stereo in my 05DAK
thats a good question, i went with a 4 channel for my speakers and a seperate one for the sub, but if you just want to get a four channel for them it might work. you should be able to get one with built in cross overs to accomidate the power. go to www.crutchfield.com and look into the f and q page, see what other people have done. if you go to your local shop they will tell you to get both amps to spend more money.
Old Nov 16, 2006 | 01:31 PM
PEPPERHEAD's Avatar
PEPPERHEAD
Morning Jaybird,
You can run that 4 channel amp if you want. Use channels 1-2 for your fronts and bridge 3-4 for your sub. As long as it puts out enough to power everything. I wouldn't amp the rears. I wouldn't even use the rears as all they will put out are the highs. Replace the fronts with a nice component set then add your sub. Your soundstage will be up front and sound good. Do you have a CC or QC? Any ideas as to the equipment you want to use?
Good luck with the install.
