Royal Purple
Old Nov 20, 2006 | 04:03 PM
DakotaStone's Avatar
DakotaStone
Default Royal Purple
I just put in for the first time, Royal Purple. Has anybody else used it yet? I feel a slight difference in the pick up, but I was told that I'll feel it after the second change.
Old Nov 20, 2006 | 05:28 PM
Drakkon's Avatar
Drakkon
Default RE: Royal Purple
the first change it should mostly be still cycling through the old that is still in the system. you are getting the placebo effect right now...it feels different cause its something different. i bet if you took it to a dyno performance diff would be nill. The second change should get all the old junk outta there and your good to go.
Old Nov 23, 2006 | 01:36 PM
Boilerman's Avatar
Boilerman
I've never used R/P oil, but I can tell you that the gear oil is some good stuff. I used in the transmission of my Harley and it made a world of difference. I highly recommend their product. I did lots of research on it too.
Old Nov 24, 2006 | 04:27 PM
DakotaStone
I found that there is a difference in the gas mileage. I drove from Portland, OR, to Yakima, WA, which is about 180 miles on half a tank of gas. That's including a lot of rolling hills and a small pass. It feels like it's running a lot smoother too. Starting to like it a lot and I'm already recommending it to friends and family.
