DOOR PANELS
Old Jan 8, 2007 | 04:44 PM
datonamanmike's Avatar
datonamanmike
Default DOOR PANELS
im looking for a blow up pic of door panel removal
and detials of how to remove door panels ??
any help is welcome thanks in advance
great site thanks for letting me join
Old Jan 8, 2007 | 05:58 PM
dontam's Avatar
dontam
Default RE: DOOR PANELS
Just did it last month. Behind the inside handle there is a cover, pop it open and remove the screw, In the pull handle removed that screw. On the bottom of the door panel remove two screws. Then gently lift up, then out. You will have to unhook the door handle latch by rotating the clip. Its easy. I just put in four Kicker 6.5 in an hour.
Hope this helps.
Old Jan 10, 2007 | 05:41 AM
jimboscomp's Avatar
jimboscomp
I'm taking my door panels off in the next couple of days to install a new light in each one, I'll get you a picture tutorial on how to do it by saturday evening
Old Jan 11, 2007 | 03:51 AM
Frenchy's Avatar
Frenchy
I recommend making sure you unattach the handle, cuz if you don't well, let me tell you what, I bent mine, slightly, and the doors wouldn't lock, and it was alllllllll messed up.
So make sure you remove that after the door panel is off..... ;-)
