Who's got the rear leveling lowering shackles???
Old Jan 28, 2007 | 11:03 PM
dakoduh's Avatar
dakoduh
Default RE: Who's got the rear leveling lowering shackles???
So how much does it lower the rear end anyway? Are they for a 4x4? Anyone have an ebay link? thanks
Old Jan 28, 2007 | 11:48 PM
snobrdrdan's Avatar
snobrdrdan
you can adjust from 1.25" or 1.75" to lower the rear
They fit both the 4x2 & 4x4 since they have the same ride height
link:
http://cgi.ebay.com/ebaymotors/SHACK...spagenameZWDVW
Old Jan 29, 2007 | 01:36 AM
superdak05's Avatar
superdak05
replacing the shackles are easy, but remember there is a left and right. if you get them mixed up they wont fit.
Old Jan 29, 2007 | 01:53 AM
dakoduh's Avatar
dakoduh
hey thanks snowbirdman-I'll check it out
Old Jan 29, 2007 | 03:27 AM
snobrdrdan's Avatar
snobrdrdan
ORIGINAL: superdak05
Are they labeled?? They looked like the same part to me
snobrdrdan's Avatar
snobrdrdan
ORIGINAL: dakoduh
LOL
It's snobrdrdan = snowboarder dan
Old Jan 29, 2007 | 01:34 PM
superdak05's Avatar
superdak05
no they are not labeled, but if you put then next to each other you will see that the bottom is wider than the top. and when next to each other they have to curve away from each other. its not much but enough to make it so they will fit.,if the curve is toward each other than they are backwards. so if you are looking at them next to each other and they curve away, the left is for the left and right is for the right. from looking at the back of the truck. and if you have a problem getting the bolts off, it would be a good idea to get new ones before you start.
Old Jan 30, 2007 | 06:25 AM
snobrdrdan's Avatar
snobrdrdan
Hmmm....so they curve a little....I'll have to remember that.....thanks man!
Did you buy new bolts? If you did, how much were they (out of curiousity)???
Old Jan 30, 2007 | 12:51 PM
superdak05's Avatar
superdak05
i did not need new bolts. i had mine installed within the first six months so bolts were still pretty new. any parts store would carry them. cant be no more than 5 bucks
Old Feb 1, 2007 | 05:29 AM
snobrdrdan's Avatar
snobrdrdan
Well thanks for the heads up again
Guess I'll just have to wait until spring to find out what I'm working with
