oil change and lube
Old Mar 17, 2007 | 01:53 PM
momopar's Avatar
momopar
Default oil change and lube
For those who change their own oil. Are there any components to lube on our trucks? I'm getting ready to change my oil and at first glance I didn't see any grease fitting.
Old Mar 17, 2007 | 02:00 PM
superdak05's Avatar
superdak05
Default RE: oil change and lube
be very carefull when changing your oil. if you notice the drain plug is right abve the cross member. if you dont get the funnel in the correct spot you will have oil every where. as for the filter its simple. as far as grease i dont know. i go and get my oil changed. its worth the 35.00 to see someone else get drenced in oil
Old Mar 18, 2007 | 11:49 PM
momopar's Avatar
momopar
I checked the manual and it dosen't say much about lube
Old Mar 18, 2007 | 11:52 PM
Ozni's Avatar
Ozni
yea basically every oil change or two look for grease tit and grease it.
