Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
- Dodge Ram: How to Check Tire Pressure
Step by step instructions for the do-it-yourself repairs
Tire Pressure Monitoring System?
I was looking through the manual of my Durango and it says that it would have a tire pressure monitoring system on it but when I look through the menu options there is nothing there. I have the Heat model and I do not care about the constant monitoring I just want to make sure that if one does go low that there is some sort of warning light or notification that would come on? Thanks!
The TPMS light only comes on if there is a problem with one of the tires. Usually there is not a constant monitering option. The best way to check the system is to jack up one tires and take air out of it. The TPMS light should come on in the dash.If not than you can take it to a credible tire facility and have them check your system.
