3rd Gen Durango 2011+ models
Shifting Problems or NOT???
Old Mar 18, 2016 | 11:56 AM
bigvin21's Avatar
bigvin21
Originally Posted by DodgeCares
Queens,
This TSB is hot off the press. Perhaps will help you!!!
NUMBER: 19-004-11
GROUP: Steering
DATE: August 19, 2011
SUBJECT:
Shudder And/Or Bump Felt Through The Steering Wheel Under Moderate Braking And/Or
Driving Over Rough Roads
OVERVIEW:
This bulletin involves road testing and if necessary replacing the intermediate shaft.
MODELS:
2011-2012 (WD) Durango
2011-2012 (WK) Grand Cherokee
NOTE: This bulletin applies to vehicles built before July 01, 2011 (MDH0701XX).
SYMPTOM/CONDITION:
Shudder and/or bump felt through the steering wheel under moderate braking or driving
over rough roads. This can be caused by spline stick/slip from the intermediate shaft.
DIAGNOSIS:
If the customer describes the symptom, perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 (AR) 05057539AD Shaft, Steering Column Intermediate
NOTE: The new lower intermediate shaft must have a green dot on the assembly,
near or on the label (Fig. 1). If a green dot cannot be found return and reorder
Hi Dodgecares,
I have had this software update done twice within the last year. The first time it fixed my problem for about 4-5 months and then the symptoms came back. I had it done again in January and the symptoms came back after a month. Any suggestions?
Old Mar 18, 2016 | 01:58 PM
DodgeCares's Avatar
DodgeCares
Has the dealership performed the steering column intermediate shaft replacement in addition to the software update, bigvin21?
Old Mar 18, 2016 | 02:02 PM
bigvin21's Avatar
bigvin21
Sorry Dodgecares, I am talking about TSB 18-035-11, I apologize, I didnt mention that.
Old Mar 18, 2016 | 02:21 PM
DodgeCares's Avatar
DodgeCares
In that case, I would have a dealership perform TSB 19-004-11. It addresses a similar symptom in a different manner, so maybe it will permanently do the trick for you.
Old Mar 18, 2016 | 02:30 PM
bigvin21's Avatar
bigvin21
Thanks! I will give it a shot.
Old Mar 18, 2016 | 03:13 PM
DodgeCares's Avatar
DodgeCares
Keep us posted!
Old Apr 11, 2016 | 12:26 PM
adbutz's Avatar
adbutz
I also have this issue in my 2012 RT. To me it seems like the AWD is locking then quickly releasing. It seems to do it more when the vehicle is hot and as previously indicated coming off the highway seems to play a major role in the vehicle acting up. I've had it in a couple times and is likely going back in the near future.
