3rd Gen Durango 2011+ models
Limited Slip
Old Dec 12, 2011 | 05:45 PM
switchblade906's Avatar
switchblade906
Default Limited Slip
I have a 2012 R/T and want to know if it has a limited slip or posi rear end.
Old Dec 12, 2011 | 06:49 PM
TonyCrew's Avatar
TonyCrew
what does the window sticker say? also, are there a bunch of gangster looking guys hanging out underneath the rear?? If not then you don't have a "possy(e)" rear lol.
Old Dec 12, 2011 | 08:14 PM
switchblade906
Im gonna go check the glove box now.
Lol sorry, i was on my phone getting my windows tinted and didn't really check spelling...
Old Dec 12, 2011 | 08:40 PM
switchblade906
So it says everything under the sun and more but nothing about the rear end lol.
Old Dec 12, 2011 | 09:13 PM
shelbymopar89's Avatar
shelbymopar89
Out of the owners manual
Traction Control System (TCS)
This system monitors the amount of wheel spin of each of
the driven wheels. If wheel spin is detected, brake
pressure is applied to the slipping wheel(s) and engine
power is reduced to provide enhanced acceleration and
stability. A feature of the TCS system, Brake Limited
Differential (BLD), functions similar to a limited-slip
differential and controls the wheel spin across a driven
axle. If one wheel on a driven axle is spinning faster than
the other, the system will apply the brake of the spinning
wheel. This will allow more engine torque to be applied
to the wheel that is not spinning. This feature remains
active even if ESC system is in the “Partial Off” mode.
Refer to “Electronic Stability Control (ESC)” in this
section for more information.
Old Dec 12, 2011 | 09:34 PM
switchblade906
Thanks
Old Oct 20, 2012 | 06:53 PM
Waynead's Avatar
Waynead
So are various grinding sounds normal as the traction control system kicks in?
Old Oct 20, 2012 | 08:58 PM
kingofwylietx's Avatar
kingofwylietx
My wife's Honda made a bunch of noise when the traction control kicked in, similar to what antilock brakes sound like when they are pulsing. That could be interpreted as a grinding noise.
Old Oct 23, 2012 | 10:32 AM
coldsteel's Avatar
coldsteel
Could be...TCS applies the brakes individually to different wheels via the ABS pump. Those pumps make a ton of noise when active.
I have had my D for 18 months and have never had the TCS kick in. I must be doing it wrong.
Old Oct 23, 2012 | 12:57 PM
Waynead's Avatar
Waynead
Frequently there is also a feeling like the rear end is slipping just a split second before it catches when accelerating from a stop. I"m assuming these are all just quirks of the vehicle.
