3rd Gen Durango 2011+ models
safe lifting points for the Durango?
Old Jan 8, 2012 | 09:15 PM
dewright's Avatar
dewright
Default safe lifting points for the Durango?
Hey guys, i was wondering where it would be safe to jack up my 2012 Durango from to rotate tires and general maintenance. I would like to use the lift points that are shown in the owners manual to put my jack stands on. It looks like i could lift the front end by the subframe crossmember just in front of the oil pan were the skid plate is attached. But i am not sure what would be safe to lift the rear end from. The rear differential is aluminum and looks fragile and has rubber mounts to the body. Can i lift each side by the lower aluminum control arm where the spring or shocks are attached? Thanks.
