TailLight Removal
My 2011 Durango came without wiring to the liftgate switch just inside the left taillight. I'm hoping the wiring is just hanging behind the taillight, but I can't quite figure out how to get the taillight out. I removed the two pins at the rear, but with gentle pulling didn't want to come out. See picture. Can someone tell me what needs to be done? Pictures if possible.
Hope my picture comes through as I've not done this before.
As mentioned above, remove the pins by prying out the center section:
https://dodgeforum.com/forum/attachm...htfastener.jpg
Then after the pins are out, pull the taillight assembly STRAIGHT back. : )
I had mine out about a week ago; after you get the 2 pins out you have to pull to the rear really hard. I couldn't do it so got a small tool with a "L" shaped hook and pulled really hard and it came right out.
