3rd Gen Durango 2011+ models
Noise coming from front left wheel on reverse
Old Mar 10, 2012 | 01:33 PM
Myrest's Avatar
Myrest
Default Noise coming from front left wheel on reverse
Hello All,
Title says it all... When I put the D on reverse and accelerate a bit, there is a noise coming from the front left wheel. It most likely sound like the sound produce by a rusty break pad.
If I apply break and press gaz, it make the noise even if the truck is not moving. Look like something is slipping under there
Could it be something with the AWD system? Someone got any clue?
Thanks!
Old Mar 10, 2012 | 04:11 PM
NY-Durango's Avatar
NY-Durango
I had a similar noise coming from left rear that I only heard while moving very slow such as pulling out of driveway. I mentioned it to dealer at next oil change and they said it was a buildup of brake dust in rear wheel. Haven't heard it since they fixed it a month ago.
Old Mar 20, 2012 | 06:01 PM
dsolters's Avatar
dsolters
I have the same noise while backing up or at the end of a forward stop. Sounds like something grinding in the rear brakes. Took it to Dealer twice and they couldn't replicate. I am thinking, how can they miss it as it happens all the time with me. Maybe a test drive with the technician is in order. 2012 D
