Cabin Air Filter replacement
Amazon says it has a charcoal replacement. Can anyone that replaced theirs verify the filter has charcoal in their?
It should be easy to tell the difference between a plain all white filter vs a charcoal that has black charcoal in its media.
couple comments, all the cabin filters should be charcoal. they will look 'dirty' when you take them out of the box. like a filter that has been in way too long and needs replaced. that's the charcoal. its gives the filter a grayish or 'dirty' look to it.
also, when you put the filter back in, make extra sure to get the cover firmly and securely in place. a only slightly gaping cover can cause a 'whistle' in the air flow when Recirc is turned off and the fan speed is med - high.
