3rd Gen Durango 2011+ models
Tow/Haul button
Old May 13, 2012 | 11:25 PM
safford197's Avatar
safford197
Default Tow/Haul button
After reading in the manual about the tow / haul button and how it forces the tranny to drop down one gear from the normal set point I decided to give it a try as a "sport" mode button. I could certainly notice a difference.
My question is has anyone else tried this and is there any detrement to the vehicle if I were to use this frequently?
Thanks!
Old May 14, 2012 | 03:14 AM
MoparMan1991's Avatar
MoparMan1991
http://adventure.howstuffworks.com/o...et-bumper2.htm
Old May 14, 2012 | 08:19 AM
CMil527's Avatar
CMil527
Haven't tried ur in my D but used to do ur all the time on my
'02 ram without issue...maybe dodgecares will chime in and shed some light on potential damage that could be done?
Old May 14, 2012 | 10:00 AM
DodgeCares's Avatar
DodgeCares
CMil,
I have not read anything about specific damage that would be done if operating in this manner. Most likely your MPG's would be affected negatively though.
Old May 14, 2012 | 11:45 AM
CMil527's Avatar
CMil527
Originally Posted by DodgeCares
CMil,
Thanx man I wouldn't think it would cause an issue either its basically like driving a car with a selectable overdrive.
Old May 14, 2012 | 12:14 PM
safford197's Avatar
safford197
Originally Posted by MoparMan1991
Good read - its mostly mirrored in the user guide for the D.
After my first oil change I'm going to explore the use of this mode more as I don't like how eager the D is go upshift and the Tow/Haul button mitigates this issue.
Old May 14, 2012 | 12:53 PM
Gibson74's Avatar
Gibson74
I just got a 2012 Citadel Hemi, and traded in a 07 Cherokee SRT8 so there was some sport withdrawl for me. I find myself using TOWMODE alot to give a little more aggressive shifting when you need to make time in traffic. It especially helps if you like to use the gears to control speed in certain scenarios. I'm so used to using the gears on my old SRT8 that i find myself using towmode and top gear limit on the D to get a close effect to what I was used to. When I want to "chill" driving or save gas, towmode off, and no top gear limit. The D does come more alive when you tame the gears via TOW mode and gear selection.
