3rd Gen Durango 2011+ models
2011 rt 8 speed swap
Old Sep 13, 2012 | 04:01 PM
urgeman's Avatar
urgeman
Default 2011 rt 8 speed swap
I'm thinking about getting a 2011 rt, but you think it will be possible to swap a 8 speed tranny in the future?
Old Sep 13, 2012 | 04:46 PM
kingofwylietx's Avatar
kingofwylietx
Not being a transmission specialist, I can't see any reason why you can't physically do it (may need a different drive shaft). The software/computer stuff is what I think you would need to investigate. I don't know if the brains of the transmission are housed in the tranny, in a different module, or in the Durango engine computer. If they are in the engine computer, that could be a problem where you would also need a computer from a newer D. In that case, the costs would add up quickly.
I assume you want the performance and gas mileage advantages of the 8-speed. If that is the case, the least expensive and most reliable way to do it is just buy one when they come out. Start saving now.
Old Sep 13, 2012 | 06:29 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
I may be wrong but I believe the 8 speed is for the V6 only. Hemi is 6 speed only.
Old Sep 13, 2012 | 10:40 PM
bbtkd's Avatar
bbtkd
Initially. Eventually they'll all get it.
Old Sep 14, 2012 | 12:32 AM
Scottina11heat's Avatar
Scottina11heat
the 5.7 hemi will get the 8hp70 ZF 8 speed
Old Sep 14, 2012 | 05:01 PM
budoboy1's Avatar
budoboy1
You will need the transmission control module besides the trans and I don't know if it would sync to the new motor's computer
Old Sep 14, 2012 | 05:24 PM
Scottina11heat
the 2014's are also going to a new electrical architecture....FYI
Old Sep 15, 2012 | 01:24 AM
IndyDurango's Avatar
IndyDurango
New electrical arch is WAY past due. Welcome to 2009 Chrysler.
That media center the Gen3 has been forced to accept is, shall we say, "less than optimal."
