3rd Gen Durango 2011+ models
Alignment issue sort of
Old Nov 11, 2012 | 12:25 AM
MG2012CREW's Avatar
MG2012CREW
Default Alignment issue sort of
I have a '12 crew, when im on the road (street or freeway) driving straight the steering wheel is always facing a few degrees to the right. If i let go of the steering wheel is doesn't drift to any side, so it doesn't seem to be an alignment issue. Any ideas?
Old Nov 11, 2012 | 08:22 AM
firetruckguy's Avatar
firetruckguy
You can have an alignment shop center the wheel. They will center the wheel and then adjust the toe to bring it back within spec. You may want to check with your dealer and see if they can get it under warranty.
Old Nov 11, 2012 | 09:54 AM
golddogs's Avatar
golddogs
I have had this happen twice with two of our minivans. They were both brand new. I also have this with my 2013 Durango R/T, not as bad though. Each time I took it back to the dealer and they took care of it no problem. The first time I take the R/T in I will address the issue. Don't hesitate to take it in and have the adjust it. Seems like a common problem.
Old Nov 11, 2012 | 03:22 PM
MG2012CREW's Avatar
MG2012CREW
Will take to the dealer then. Thanks
Old Nov 12, 2012 | 04:02 PM
mmillerao's Avatar
mmillerao
Had the exact issue. Dealer moved the wheel to the left a couple of degrees, no charge. Not an alignment issue in my case. Wish he had moved it one degree instead of two but can live with it as is till next time in the dealership for maintenance.
