3rd Gen Durango 2011+ models
Recent Updates
Old Feb 16, 2013 | 10:43 AM
DurangoNky's Avatar
DurangoNky
Default Recent Updates
Wife had our 2011 Durango serviced and after looking at the service papers they also did some updates. Can someone give me a run down on what these are for?
181906L9 PCM Flash Update
18803297 RRT 11-047 Flash WCM
18890197 TIPM Flash Update
18193191 TSB 0805311 Theft Alarm Update
Thanks for your time and help
Old Feb 18, 2013 | 02:23 PM
DodgeCares's Avatar
DodgeCares
In the order you listed. I believe the last 2 are both under the third TSB below.
NUMBER: 18-035-11
GROUP: Vehicle Performance
DATE: July 11, 2011
SUBJECT:
Flash: Driveability And Transmission And Heating And A/C Improvements
OVERVIEW:
This bulletin involves flash reprogramming the Powertrain Control Module (PCM) with new
software.
MODELS:
2011 (WD) Durango
2011 (WK) Grand Cherokee
NOTE: This Service Bulletin applies to WK vehicles equipped with a 5.7L engine
(Sales Code EZH) and 545RFE transmission (Sales Code DGQ) built before
April 4, 2011 (MDH 0404XX).
NOTE: This Service Bulletin applies to WD vehicles equipped with a 5.7L engine
May 10, 2011 (MDH 0510XX).
SYMPTOM/CONDITION:
Some customers may notice any of the following;
a. A/C not cooling enough or feel a warm air burst. This condition happens if 3 to 4
wide open throttle event happen during the same drive cycle or when towing a
trailer. (WK Body Only)
b. Heater warm-up time is too slow at or below 14° F (-10° C). Idle RPM has been
increased for improved heater warm-up times. (WK Body Only)
c. Loud cooling fan or fan run on high for long periords with the A/C on. (WK and WD
Bodies)
Driveability Improvements
a. Fuel odor. This condition is noticeable in hot ambient temperatures, while towing a
trailer or in stop or go city traffic. Purge flow has been increased. (WK Body Only)
b. Lacks Performance. Some driving conditions can produce circumstances where
some customers may perceive more pedal effort is required to get the Powertrain to
accelerate the vehicle as desired. The PCM calibration for pedal vs. torque
relationship was changed to allow for more torque delivery at less pedal effort/travel.
(WK Body only)
c. Knock sound. This condition happens on heavy throttle input or entry into or out of
MDS modes. The spark knock calibration has been changed to accommodate these
conditions. (WK Body Only)
d. Drone sound while operating in MDS V4 mode at steady state driving, anywhere
between the speeds of 35 to 60 mph (56 to 96 kph). (WD Body Only)
e. EVIC fuel economy calculation improvements. (WD Body Only)
f. Cruise Control cancels without driver input while in ACC mode at about 5800 RPM.
To correct this condition the cruise control cancel mode RPM limit has been raised.
(WK Body Only)
Transmission Improvements:
a. Bump feeling or clunk sound in 4WD Low during a coast down. This condition
happens at speeds between 5 to 30 mph followed by the driver letting off on the
throttle (Decel). (WK Body International Vehicles Only)
b. Too high vehicle speed needed before shifting from 3rd - 4th gear. (WK and WD
Bodies)
c. Shudder or shake feeling on wide open throttle stab. (WK and WD Bodies)
d. Harsh 1-2 upshift. (WK and WD Bodies)
e. Unexpected or busy downshift with a raise in engine speed while coasting at
between 45 and 48 mph (72 to 77 kph). (WD Body Only)
NUMBER: 08-024-11 REV. A
GROUP: Electrical
DATE: July 01, 2011
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 08-024-11, DATED JUNE 15,
2011, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDED D SERIES TRUCKS AND
SPECIAL CONSIDERATION FOR HANDLING VEHICLES EQUIPPED WITH A
CUMMINS DIESEL.
THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE
TRANSMITTAL (RRT) 11-047. ALL APPLICABLE SOLD AND UN-SOLD RRT VIN's
HAVE BEEN LOADED. TO VERIFY THAT THIS RRT SERVICE ACTION IS
APPLICABLE TO THE VEHICLE, USE VIP OR PERFORM A VIN SEARCH IN
TECHCONNECT. ALL REPAIRS ARE REIMBURSABLE WITHIN THE PROVISIONS OF
WARRANTY.
HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS
AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF
THE wiTECH DIAGNOSTIC APPLICATION WINDOW.
THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE **12.01** OR HIGHER TO
PERFORM THIS PROCEDURE.
SUBJECT:
Flash: Intermittent No Start Or Intermittent RKE Function
OVERVIEW:
This bulletin involves flash reprogramming the Wireless Ignition Node (WIN) with new
software.
NUMBER: 08-053-11
GROUP: Electrical
DATE: August 27, 2011
SUBJECT:
Flash: Vehicle Theft Alarm Intermittently Sounds, No Start
OVERVIEW:
This bulletin involves flash reprogramming the TIPM with new software.
MODELS:
2011 (RT) Town & Country / Grand Caravan
2011 (DJ) 2500 Pickup
2011 (DS) 1500 Pickup
2011 (DX) (Mexico) Reg Cab Chassis
2011 (D2) 3500 Pickup
2011 (JK) Wrangler
2011 (J3) (CKD) Wrangler
2011 (J8) (CKD) Wrangler
2011 (KA) Nitro
2011 (KK) Liberty
2011 (K1) (CKD) Cherokee
2011 (WD) Durango
2011 (W2) (CKD) Grand Cherokee
NOTE: This bulletin applies to RT, DJ, DS, DX, D2, JK, J3, J8, KA, KK, K1, WD, WK,
and W2 vehicles built prior to May 9, 2011 (MDH 0509XX) equipped with
Security Alarm (sales code LSA or LSB) or Premium Security Alarm (sales
code LSC).
SYMPTOM/CONDITION:
The customer may complain of following conditions:
· The vehicle theft alarm intermittently sounds for no apparent reason.
· Multiple attempts are required to start the vehicle before the vehicle will start.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation
No:
Description Amount
18-89-01-96 Module, TIPM - Inspect (C) 0.2 Hrs.
18-89-01-97 Module, TIPM - Inspect & Reprogram (C) 0.2 Hrs.
