Originally Posted by IEWRX
(Post 3013053)
As the problem has gotten worse, I started to wiggle the M25 fuse and both times I did this it started afterward. Once right up, and a second seperate time a little hesitation but started on the first try after that.
It is doing it now cold or hot, does not matter. Scheduled an appointment for Monday at the dealer boy will I be tired, but it is bad now and gotta get it looked at. Why did it not happen before I went over the basic mileage. Starting to doubt my thought of a 2014 Durango purchase to replace this one..... Did try M25 and J17 without any conclusive result...when it start with hesitation it feel like it run on "5 cylinders"? |
Originally Posted by wildspeed
(Post 3013074)
Look like we are having the same issue.
Ok took it in this morning and of course when I got in to take it over, no problem. At the dealer started no problem. Anyway, got a call from the dealer about 11:43 stating the it was done and they did a flash per TSB 08-053-11 looks like that is for the alarm system. About 50" later got a call back from the dealer and it was not starting, it actually acted up there. About 2:40 they called back and stated they replaced the push button start and programmed. So far it has been started twice and no issues. The adviser said this is the first time he has seen the push button needing to be replaced. It was diagnosed as push button module/adapted loss of signal.
While I was there had the radio/Nav flash done and it is at least holding my home in the NAV. |
Good to hear keep us posted
(Post 3013868)
While I was there had the radio/Nav flash done and it is at least holding my home in the NAV. Hopefully that was the issue, but doesn't really explain the intermitent rought idling when the car does start... |
Not sure where I read it, but I did read somewhere else that there have been communication issues within some of these cars with push buttons and RF signaled systems.
Some are being affected by radio interferences from other devices. The button is simply a switch...the module it activates communicates with the ecm and TIPM module STEVE |
(Post 3013927)
I wonder if they took out the push button and try to start with the key...?
Oh well so much for that. Did same thing three times this morning. Guess it is back to the dealer.
Got the car back from the dealer...after a week :mad:
They replaced the TIPM...for the second time...:icon_rolleyes: apparently was loosing power on pin 10, internal intermitant open in fuel pump circuit.... what ever that mean. Let's hope that fix it.... |
Wow thats ridiculous...lets hope its fixed!
