3rd Gen Durango 2011+ models
Warranty - Power Liftgate issue
Old May 20, 2013 | 08:17 PM
woblik's Avatar
woblik
Default Warranty - Power Liftgate issue
My power liftgate started having problems closing. It would shut, but wouldn't pull all the way in. So i called the dealer, told me they could fit me in 9 days later (pretty convenient for a hatch that wont close completely). Dropped it off this morning, they called me at 2 to say it was done. Apparently the module that pulls the hatch closed needed reflashed, said there was a service bulliten regarding it. Got it back now, alls good in the hood.
Thought id post in case anyone else has issues.
Old May 20, 2013 | 08:21 PM
GizmoDurango's Avatar
GizmoDurango
Glad it worked out for you! I need to get to the dealer and make sure all of my TSBs are done. Were there any pre-failure signs, like it didn't respond to the button, or anything like that prior to it not closing fully?
Old May 20, 2013 | 09:15 PM
woblik's Avatar
woblik
Not really, just quit working
Old May 20, 2013 | 10:41 PM
zaktrafton's Avatar
zaktrafton
So in 10 years will we be ableto replace the power actuator with a normal strut and slam it home like it should be? Thats my worry.
Old May 21, 2013 | 07:52 AM
coldsteel's Avatar
coldsteel
I don't think so; there is no physical linkage between the release handle and the latch. The release handle on the liftgate just tells the computer to release the latch and push open the liftgate.
Old May 21, 2013 | 10:03 AM
DodgeCares's Avatar
DodgeCares
This is the TSB on the liftgate issue described above.
NUMBER: 08-005-13
GROUP: Electrical
DATE: February 01, 2013
SUBJECT:
Flash: Power Liftgate May Not Power Open Or Close
OVERVIEW:
This bulletin involves reprogramming the Power Liftgate Module with new software.
MODELS:
2011 - 2012 (WK) Grand Cherokee
2011 - 2012 (WD) Durango
NOTE: This bulletin applies to vehicles equipped with Power Lift gate (sales code
JRC) between March 1, 2010 (MDH 0301XX) and March 1, 2012 (MDH 0301XX).
SYMPTOM/CONDITION:
The customer may experience the Power Lift Gate not opening and closing under power.
Upon further investigation the Technician may find that B1882 Power Liftgate Position
Sensor 1 Circuit set.
Updating the software will correct the conditions listed above.
DIAGNOSIS:
If the customer describes the symptom/condition or if the technician finds the DTC,
perform the Repair Procedure.
Old May 21, 2013 | 10:42 AM
zaktrafton's Avatar
zaktrafton
The power liftgate is a great feature but i hope it lasts. Ive had issues with sunroofs in the past.
Old Oct 16, 2013 | 11:25 AM
Trace3rd's Avatar
Trace3rd
Took the Durango to the dealer yesterday to have TSB 08-005-13 (listed above) performed, because the gate did not shut completely and latch after it closed the other day. The dealer said the TSB was not for my VIN, and they could not duplicate the issue. However, I noticed the "chime" was not working when we cycled the gate open and shut, and brought this to the dealership's attention. They checked to make sure the "chime" was selected in the set up, then told me there was nothing they could do, but they would research it and give me a call when they knew something. So I have the Durango back, the gate is working, but does not "chime" when opening or closing even though it is selected in set up, and I guess the above mentioned TSB does not apply to all 2012 Durango's.
Old Oct 16, 2013 | 11:56 AM
SLAINTE06's Avatar
SLAINTE06
[QUOTE=DodgeCares;3021403]This is the TSB on the liftgate issue described above.
NUMBER: 08-005-13
GROUP: Electrical
In resoponse to this
Can Dodge cares tell us how to vertify this with our VIN , is there a way to do this online?
Old Oct 16, 2013 | 12:12 PM
FSTDANGO3's Avatar
FSTDANGO3
Even if it doesnt apply...If the damn hatch isnt working make them fix what is broken under warranty
STEVE
