3rd Gen Durango 2011+ models
windshield washer pump
Old Aug 1, 2013 | 02:23 PM
safford197's Avatar
safford197
Default windshield washer pump
Tried searching for a thread on this with no luck but in a nutshell my washer fluid won't spray anymore. I can hear the whirring of the pump and a little fluid comes out but not enough to reach the windshield. I checked the obvious, filled the fluid tank, followed the lines to check for kinks but I'm at a loss as to why this has stopped working. Any ideas?
Old Aug 2, 2013 | 12:30 PM
Fullslp's Avatar
Fullslp
Disconnect the lines from the sprayers and engage the pump. There should be quite a bit of fluid coming out of both lines. If so then you need to remove and soak your sprayers (20-30 min) in alcohol. use some heavy silicone on the painted portion of the sprayers, this will save the paint from the alcohol.
If you are not getting a solid stream of fluid from the hoses then disconnect them from both sides and use compressed air to clear the lines.
If all this checks out then you have either a leak somewhere inline. (use a separate hose from an auto parts store to bypass and check).
or your pump is faulty. rare though.
good luck.
Old Aug 29, 2013 | 01:12 AM
safford197's Avatar
safford197
Default Update
I tested the nozzles with no problems and decided it was time to see the dealer. Turns out the pump went bad. It was still trying to pump and therefore making a buzz (as it always did) but the dealer had to replace the pump to fix the problem. There was no charge for the repair as it was under warranty.
Old Sep 1, 2013 | 11:36 PM
Fullslp's Avatar
Fullslp
well chalk one up to "rare" glad you got it fixed.
