Hello friends
I wanted to replace my normal Dodge Durango's headlight with projector hid xenon model.
As you know that the OEM r/t model come in black basel with projector xenon so this got especial connection. Does any one knows how can I do so? Is there any connector adapter that do that???
Has any one did this project in his own. Please I bought the two headlamps from ebay and needs your help to put them on my crew durango.
Thanks
Thanks
I DID THIS WITH MY SXT
PARTS NEEDED ASSUMING THE BALLAST ARE INCLUDED
(2) CANBUS FIX FOR LIGHT FLICKER
http://www.kbcarstuff.com/CANBUS-Fix-p/cbfix.htm
(1) drivers repair harness and plug-68052582AA (google search) pricey
(1) 12 pin connector for passenger side (comes with extra wire) this you need to pull out slightly to get the female pins connected
http://www.mouser.com/ProductDetail/...2btte7bY%2ba8=
(2) female connector (i ewould get at least 6 for slip ups)
http://www.mouser.com/ProductDetail/...pxBV97zB5Nm9KV
If i recall the canbus fix has the oem mopar hook up, just one end of it needs to be clipped. below is a wire configuration. Splices from pepboys or homedepot, just get the right size for the wire. PAY ATTENTION TO POSITIVE AND NEGATIVE, WHICH SHOULD BE MARKED ON THE CANBUS FIX
refer to this link for addtional help.
http://www.jeepgarage.org/f177/how-t...tml#post648306
thanks to scottina11heat for the great write up, pretty much plug-n-play after the bumper,grille and headlight removal.
This is great info/write up, but Im not so sure I would add this to my mod list if this is considered plug and play
^^^yeah, to remove the headlights you have to remove the bumper and if i remember, the grille. After that its plug and play once assembled. The price to mod. Very first mod I did was get rid of the chrome headlights. Loved the look of the RT black bezel.
