3rd Gen Durango 2011+ models
Nitto Terra Grapplers - Thoughts?
Old Nov 3, 2013 | 10:50 AM
cek260's Avatar
cek260
Default Nitto Terra Grapplers - Thoughts?
I decided to get rid of the 265 50 R 20 Forterras currently on my 2013 Crew after having had these tires before and really not thrilled with their perfomance in wet/snowy weather. I'm leaning towards the Nitto Terra Grapplers but am confused about which size. I know I can get the same size as the OEMs but I like the idea of bumping up to the 275 55R 20s. Before pulling the tirgger it would be great if I can get some thoughts on the two sizes- pros/cons, experiences, etc. My main concerns with the 275 55R 20s are how correctly calibrate the speedo (is that even possible / something any tire shop can do, or is it a dealer issue?) and whether or not there is any rubbing? I know some folks use spacers with the larger tires, but would like to avoid that if at all possible. Also, I would definitely install a 1-1.75" leveling kit at some point, but am not sure how much additional stress/wear that would put on the front end.
Thanks!
Old Nov 3, 2013 | 11:11 AM
FSTDANGO3's Avatar
FSTDANGO3
I had these tires on my Gen 1 D
They work Great in all conditions
STEVE
Old Nov 3, 2013 | 09:07 PM
zaktrafton's Avatar
zaktrafton
With that larger tire your speedo will read 3 mph slow at 60 mph. So speedometer says 60 you are actually going 63 and so on.
Old Nov 4, 2013 | 04:37 PM
rvarner's Avatar
rvarner
I had the Terra Grapplers on my Sport Trac that I traded in for the Durango and they are great tires. They definitely give you more of an off road look. I like the more street aggressive look for this particular vehicle but those Nittos will work great for your use!
Old Nov 4, 2013 | 06:02 PM
fishandgrits's Avatar
fishandgrits
If they had a small lift for the Durango I think they would look great. You might need a few more mods to create that pre runner look that the tires will Nittos will end up giving you.
They are great tires though, no doubt!
Old Nov 5, 2013 | 09:48 AM
JJEH's Avatar
JJEH
I run the Terra Grappler on the Ram and I'm satisfied.
Old Nov 5, 2013 | 01:35 PM
NUTTS12CREW's Avatar
NUTTS12CREW
Check out the new Nitto Crosstek. i just put a set of the stock 18's on my D and they've been great so far in the dry and heavy wet. Snow will be the next test
Attached Thumbnails Nitto Terra Grapplers - Thoughts?-crosstek_tire_suv-1-.jpg
Old Nov 5, 2013 | 09:32 PM
cek260's Avatar
cek260
Thanks for the input. Will probably go with the stock size Terra Grapplers- tirebuyer.com has them for a decent price plus there's a coupon code that will knock off 10%.
fishandgrits - I get what you're saying. Have side steps already and am leaning towards a Rocky Road Outfitters front end leveling kit, there's a number that have good success with it over on the Jeep WK2 forums.
Old Nov 12, 2013 | 02:55 AM
duke07's Avatar
duke07
To me, Terra Grapplers are one of the best AT tires. I had a set and they performed well on and off the road. Had no problems with them.
