Oil usage
I change my oil every 5000 miles in the Durango. Checked my oil today about 15 mins after getting home.
The dipstick shows oil in the lower hole but not in the upper hole. Is this 1/2 qt low? 1 quart low?
It has 13,800 miles now. I've run Mobil 1 5w20 since 3,000 miles when I bought it in May 2013 as a dealer manager demo.
How about you other hemi guys. How much oil do you use?
drain the water out and put real oil in. valveoline premium blue, 15w 40 it is the factory fill for the cummins diesel. been using it fore 4 years. i my 01 dak V6 3.9 this week the over nite temp was 15 f and it started just fine. and it has the zinc in it.
out of curiosity, why does someone want to put 15w40, the factory fill for a cummins diesel, into a 5.7l hemi where factory fill is 5w20?
I dont use more than an 1/10 of a quart and that is what I catch in my catch can. So I have no leaks. What Brand oil are you using?
I use Penzoil Ultra or Platinum and have no issues. I had an issue with Mobil 1 in my older D it would use about 1/2 quart, when I switched it to Penzoil it all went away.
If you dont have a catch can and you drive spirited frequently it could use about 1/2 qt between changes .
STEVE
STEVE
Trending Topics
i just like as thick of oil as i can get away with. i dont want the engine parts touching each other. i realty should not have told you to do what i do. after all i have only been driving / working on mopars since 1965. iam just old school all a round. get over it.
The only time my D uses oil is when I park it on an uphill incline. When I start it later, I get a big cloud of blue smoke. If this happens a coupe of times, it is slightly low. Taking it in Friday for the new oil pan fix, per the service bulletin.
