3rd Gen Durango 2011+ models
Lift Gate Interior Trim Removal
Old Jul 21, 2014 | 03:17 AM
911Boulder's Avatar
911Boulder
Default Lift Gate Interior Trim Removal
I did a quick search and couldn't find an answer, so if its been asked before, my apologies...
I need to replace a couple of bulbs on the marker lights in the lift gate... I know you need to remove the trim panels on the inside of the lift gate, and to do this you need to remove the "handle cups" on the bottom of the lift gate...
My question is:
How the eff do you get those cups out...? LOL
Thanks in advance!!!
Old Jul 21, 2014 | 08:49 AM
Waynead's Avatar
Waynead
Just pry the top edge. Worked for me. But getting the panel off without breaking the clips seems to be a challenge.
Old Jul 21, 2014 | 09:05 AM
GDM's Avatar
GDM
Take it to the dealer....they charged me $30 to replace both bulbs. Cheaper than you replacing what you will break doing it yourself....also less aggravation.
cbrrider012's Avatar
cbrrider012
You have to pull the handle cups out first. They are not terribly difficult to remove but you have to be gentle with them or they will break. Then just go around the outer edge and pull and the clips will pop out. Inevitably you will break some of the clips either pulling it out or when you put it back in due to not lining up the wholes properly because there is no room to see anything.
Old Jul 21, 2014 | 10:20 PM
911Boulder's Avatar
911Boulder
I know how to remove interior panels, I've been doing custom stereo installs and emergency vehicle installs for years now... I've just never come across these "cups" before and can't find a way to get them out... Do they just pull out, or are they affixed somehow...?
Old Jul 21, 2014 | 10:38 PM
dizney24's Avatar
dizney24
https://www.youtube.com/watch?v=yZWOx-zL_7w#t=218 look around 330 mins into the video
Old Jul 22, 2014 | 12:07 AM
911Boulder's Avatar
911Boulder
Thanks but that doesn't help... My interior trim panel wraps down and the cups go through the bottom of the panel... I need to remove the cups in order to remove the panel...
Old Jul 22, 2014 | 09:32 PM
dizney24's Avatar
dizney24
i have a 2011 R/T and removed the lift gate trim with out taking out the cups
Old Jul 22, 2014 | 10:02 PM
911Boulder's Avatar
911Boulder
I'll have to look at it again on my days off, but It looks like the cups are a part of whats holding the trim on...
Old Jul 24, 2014 | 01:33 PM
Waynead's Avatar
Waynead
Seriously- pry the top edge down. It works.
