3rd Gen Durango 2011+ models
How good is the Durango AWD system?
Old Nov 17, 2014 | 10:01 PM
  #21
FSTDANGO3's Avatar
FSTDANGO3
Originally Posted by Thekoning
Underpinnings are most certainly NOT the same.
There are a lot of common parts. Different transfer case options amd available true air ride on the Jeep
STEVE
Old Nov 17, 2014 | 10:28 PM
  #22
JRRF's Avatar
JRRF
Originally Posted by shadwell1020
I don't understand why all the car company's ditched regular 4x4 in favor of "AWD". Let's face it...it's not as good as a 4x4 truck or Jeep in any weather. Yes, it's probably better than 2WD, and it probably performs pretty well on moderately snowy, flat roads....but I doubt AWD holds a candle to the others in deep snow and or hills.
I currently have a Grand Caravan and it's mostly hills where I live, and harsh winters, so I'm a bit concerned...which is why I asked about the Durango AWD, but in my opinion, my GC with snow tires will be just as a good as the AWD Durango with OEM tires.
I mean, if you COULD choose regular 4x4 with a Hi and Lo option, or AWD, wouldn't you prefer 4x4?
You only need three letters to explain this: M-P-G. No one really needs a low range option anymore, and mpg is greatly improved without it. That's the target manufacturers need to meet. AWD is good enough for most all of us, and those that still need a low-range option, also need more clearance, and there are options out there for them to deal with those unique situations.
Old Nov 18, 2014 | 07:21 AM
  #23
supertech30's Avatar
supertech30
Guy's the terms AWD and 4X4 really don't mean anything any more haven't for years. Back in the day if you had a 4x4 it had a real heavy duty transfer case and awd was a cheaper transmission gearbox setup that just supplied a small fraction of the power to the other set of wheels. Know days manufactures use both terms for the same setups. The Jeep with Quada trac II which my 2014 Jeep overland had, has the same transfer case and front and rear diff's that my 2014 rt has only difference is the cheesy preset software preset modes hardware was all the same and the Durango is more stable in the snow because of the longer wheelbase, but the jeep is marked 4x4 and the D's maked AWD. See my point.
Old Nov 18, 2014 | 11:56 AM
  #24
ufokillerz's Avatar
ufokillerz
MP3023 on the Jeep, MP 3022 on the Dodge. The same?
Old Nov 19, 2014 | 07:47 AM
  #25
supertech30
Looking at my build sheet for my dodge the code DKAS for transfer case comes up in jeep pages as Quada Trac II which is what my jeep had in it. Allpar also lists my jeep with the Quada Trac II using the MP3022 case see here http://www.allpar.com/SUVs/jeep/spec...rand-2014.html
I wish I had a build sheet for the jeep. I am sure they are functionally the same case if not exactly the same.
Old Nov 19, 2014 | 05:04 PM
  #26
Thekoning's Avatar
Thekoning
First time driving in the snow this year
but then when i obviously went to do a drift around some back road corner, its just ugly sounds from the front axle engaging more power trying to regain traction, do these Durangos have a stability or some other type of traction system which remains on even with the traction button off?
ughhh how i wish the gen 3 had 4x4 selectable to 2x4(rwd). that would be some much more fun!
Old Nov 19, 2014 | 06:47 PM
  #27
Fullslp's Avatar
Fullslp
Brake based Torque Vectoring. It will continue to apply brakes to one or both front tires as they slip including completely cutting all usable power to the front axle if nessesary. And unfortunately you can't shut it off. You big tire boys will notice this more than us big rim boys since your breakaway traction will be more pronounced on the much larger diameter tire. LOCKING DIFFS ANYONE?
Old Nov 19, 2014 | 07:43 PM
  #28
Thekoning's Avatar
Thekoning
good info thanks fullslp.
really too bad this cant be turned off
Old Nov 20, 2014 | 03:39 PM
  #29
coldsteel's Avatar
coldsteel
There's probably a fuse for that.
Old Nov 20, 2014 | 05:40 PM
  #30
Thekoning's Avatar
Thekoning
These truck have like no fuses, all TIPM. I was looking for a fuse for the highbeams and drl's at one point but had no luck.
but yes possibly...
