3rd Gen Durango 2011+ models
2013 Wiper Issue
Old Jan 9, 2015 | 12:38 PM
Tonkie's Avatar
Tonkie
Angry 2013 Wiper Issue
I have a 2013 Durango Crew. I have been experiencing an issue where my wiper blades stop working with the smallest amount of snow build-up under the blades. Is anyone else experiencing this problem as well?
Old Jan 9, 2015 | 02:01 PM
cwilliamt's Avatar
cwilliamt
Can you be a little more specific? "Stop working" as in the wipers don't go back and forth any more...or "stop working" as in the rain-sensor doesn't work...or "stop working" as in you get streaks on your windshield? Help us help you by providing just a little more information.
Old Jan 9, 2015 | 02:31 PM
coldsteel's Avatar
coldsteel
If you are using aftermarket solid beam wipers you will get a streaking problem due to the curvature of the glass.
You need to use traditional flex beam wipers which can better conform to the glass for greater wiping.
Old Jan 9, 2015 | 04:57 PM
ufokillerz's Avatar
ufokillerz
sounds like a bum wiper motor.
Old Jan 10, 2015 | 10:25 AM
Tonkie's Avatar
Tonkie
Default reply
Stop working as in won't go back and forth at all until I get out and clear every bit of snow under the wipers. They have replaced both my mother board and wiper motor and still does it. I don't have the auto wipe sensor setting on my car. Nothing is after market.
Old Jan 10, 2015 | 10:27 AM
Tonkie's Avatar
Tonkie
Default reply
They have replaced the mother board and wiper motor only 6 weeks ago in my car at yhe dealership. QUOTE=ufokillerz;3219224]sounds like a bum wiper motor.[/QUOTE]
Old Jan 10, 2015 | 11:34 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I found this little tidbit of info, still digging for an inhibit mode for obstructions. Things are always being added and changed these days.
****Low Ambient Temperature - When the ambient temperature is below 0° C (32° F), the automatic wipers will not operate during a new ignition cycle until the wiper switch has been moved to a different position than that which was selected at the moment the current ignition cycle began, or until a vehicle speed input is detected.*******
Old Jan 10, 2015 | 12:21 PM
coldsteel's Avatar
coldsteel
I didn't know that - that obviously is the safety feature to prevent frozen wipers from burning the motor. Not a bad idea.
