3rd Gen Durango 2011+ models
best 20 inch tires for leveled durango
Old Feb 16, 2015 | 05:52 PM
the4billa's Avatar
the4billa
Default best 20 inch tires for leveled durango
can someone help me figure out best 20 inch tire to use with the rocky road leveling kit, I have dodge srt 8 reproduction rims that are made to fit on the Durango, so they do not have the offset of the oem wheels used on the jeep srt8. so when leveling 1.75 kit is installed the tires I have will look terrible anyone have any pics or suggestions thanks everyone
Old Feb 16, 2015 | 08:54 PM
Thekoning's Avatar
Thekoning
I can point you at the proper size. What offset is your rim? what kind of tires are you looking for?
Old Feb 16, 2015 | 11:59 PM
the4billa's Avatar
the4billa
Default tire size
20x9
wheel off set 34.75, there replica jeep srt8 wheels with 265-50-20 right now and that info is off the site I got rims frdom, thanks any help is appreciated
Old Feb 17, 2015 | 10:53 AM
Thekoning's Avatar
Thekoning
By judging your rim specs and using this helpful web site:rimsntires.com
265-50-20 tires have an OD of 30.5 for reference
if your looking for the largest, id say you could fit a 285-55-20 or smaller tire which has a (32.4 inch OD) , that is taller than mine but your able to do it because you have a larger offset so i wouldn't expect any rubbing. Check out what sizes the tires your thinking about getting come in and dont go larger than 32.4 OD, if your under 32inch your definitely good.
