Resetting Throttle
The instal is simple. It comes with easy to understand instructions and Sean will answer any questions you have. You get the tuner, plug it in to the port under the dash and follow the instructions. The tune installs and saves two files back to the tuner, your back up and last tune. You email the files to Sean, he modifies them and sends them back to you. After a few tanks of gas you hook the tuner up again, let it log some stats for him, and email him again. Sean will fine tune the files, custom just for you, and send them back again if changes are made. I went with the 93 octane tune for performance and WOW, there's also an 89 octane tune or 91 octane tune available. Sean will give you 89 and 93. My gas mileage has been the same unless I drive hard, which is usually the case.
He also has instructional videos on you tube fro every step. I'll attach the tuning one below.
