FOB, start up, shut down, weird issues
I have a 2012 DD that was built in Nov of 2011. I'm having some odd issues related to start up and shut down of the DD.
Issue I'm having is that with one of my keyless entry FOBs, the DD will fire up with the Start button is pushed, but then immediately die and won't turn back over until I cancel it all out and open the driver door. (doesn't happen every time, seems random when it does). Fix seems easy, right, replace the battery on the FOB? Did that, still have same issue. I'm also occasionally getting a delay often in when I 1) start the vehicle -> it'll pause for a good 3-4 seconds between hitting the button and the engine firing up. 2) Occasionally when I turn off the DD by hitting the start button again, it'll wait 3-4 seconds and then turn off. Today I had it where it stopped the car, but then the other doors didn't unlock immediately like they should have when I opened up my driver door. My only guess as to what's going on is that perhaps I need a new vehicle battery in the DD? Could that be what's going wrong? There are new batteries in my key FOBs, so that can't be them. Has anyone else run into this? Is there something else to reset or check? |
Search the forum. A guy just posted similar issues and found that when he took his key apart and metal disk had come loose and was causing the eratic behavior
Originally Posted by Wash Man
(Post 3234765)
EDIT: Found it: https://dodgeforum.com/forum/3rd-gen...-engage-2.html |
yeah, that was me. your issues sound a little different though. still I would recommend you take the fob apart and see how it looks. its pretty simple to pull apart and put back together.
Originally Posted by 2011CrewLuxSC
(Post 3234877)
Originally Posted by mmark27
(Post 3234884)
Yeah, I did see that the prongs that hold the battery tight were a little flattened, but that's it. Not sure that would do anything but we'll see. Otherwise I'll take it to the stealership if it gets worse.
Sorry to hear about your concern. Do you notice any specific conditions that your symptoms are occurring under, such as a cold start? Also, is the engine cranking when you have the delayed start? |
