3rd Gen Durango 2011+ models
2015 RT, grinding in manual mode
Old Jun 3, 2015 | 02:14 PM
mikej's Avatar
mikej
Default 2015 RT, grinding in manual mode
I have a 2015 RT, I noticed today that when in manual mode, if I'm under heavy acceleration and upshift in manual mode, I get a grinding sound from the back.
I'll start in 1st, get to about 5-6k rpms, and shift and will hear the grind as it upshifts. Does it in 1st to 2nd, and 2nd to 3rd. Doesn't do it in automatic mode.
Has anyone seen something like this? I'm kinda confused why it would only happen in manual mode....
Old Jun 3, 2015 | 06:25 PM
Turborusty's Avatar
Turborusty
It's likely what is called the HEMI fart. It's not grinding and it's the exhaust, not metal to metal.
Turborusty
Old Jun 4, 2015 | 10:48 AM
mcfarl58's Avatar
mcfarl58
Turborusty
Correct. It's standard exhaust gurgling. And it's intoxicating.
Technically speaking, it's either caused by back pressure in the exhaust system (which is the case here) or unburnt fuel getting into the exhaust and igniting with a fresh air source and heat from the exhaust (common cause if the popping is during deceleration).
Nothing wrong with it. Enjoy it. It only happens in manual mode because you don't get that high of RPMs in automatic unless you're really pushing it.
Old Jun 4, 2015 | 01:39 PM
pjw1967's Avatar
pjw1967
I recently picked up some cypress trees with the D. Had to ride with the rear hatch open about 8 inches. What a sound. Almost as good as my GTO. My wife said it sounded like a diesel.....
Old Jun 4, 2015 | 01:50 PM
mcfarl58's Avatar
mcfarl58
Grounds for divorce.
Old Jun 4, 2015 | 03:21 PM
pjw1967's Avatar
pjw1967
Can't. She knows where the money is and I don't....
