3rd Gen Durango 2011+ models
MDS(ECO) viberation
Old Apr 3, 2016 | 12:49 PM
Crankshaft57's Avatar
Crankshaft57
Default MDS(ECO) viberation
When the ECO letters come on I feel a vibration from the steering wheel. This could go on for a mile or so and then there is a jerk and everything smooth's out. Sometimes I will step on the gas and the ECO letters will go out but when they come back on the vibration will start again. Anyone?
Auggie
Old Apr 4, 2016 | 03:24 PM
DodgeCares's Avatar
DodgeCares
Thanks for reaching out. Is this something that occurs consistently? Do you feel the vibration anywhere other than the steering wheel with the ECO letters turn on? At what speed is this typically occurring? Thanks! - Kevin T, Social Connect Team
Old Apr 5, 2016 | 11:51 AM
Crankshaft57
Yes, it happens all the time. Not so much in town driving because I am on and off the throttle but at freeway speeds(60/80) with the cruise control on. As soon as the engine switches to four cyl's(MDS)the vibration starts. It seems as though the MDS is trying to but can't quite get to the four cyl mode. Then there will be a jerk and everything smooth's out. This may take a mile or two to happen. If it goes on longer I worry that harm is being done so I blip the throttle to get out of MDS, but as soon as it tries to go back the vibration starts again. I feel the vibration in the steering wheel the most but there is also a groaning noise and everything seems to be vibrating. Can the engine management system be reprogramed to eliminate this problem? 2012 Crew 5.7
Auggie
Old Apr 5, 2016 | 12:59 PM
SHO Rod's Avatar
SHO Rod
Sounds a bit like you might have a misfire that becomes more noticeable when the cylinder deactivation is active (ie: on one of the cylinders that remains on). Have you ever changed the spark plugs? It might be worth pulling the spark plugs and carefully inspecting them for one that has a different coloration than the others or possibly signs of a crack in the insulator.
-Rod
Old Apr 5, 2016 | 02:32 PM
DodgeCares's Avatar
DodgeCares
Auggie
Thanks for the follow-up. TSB 19-003-14 may relate to your vehicle. Thanks! – Kevin T, Social Connect Team
SUBJECT:
Clunk And/Or Bump Felt Through The Steering Wheel Under Moderate Braking And/Or
Driving Over Rough Roads
OVERVIEW:
This bulletin involves road testing and if necessary replacing the intermediate shaft.
MODELS:
2011-2012 (WD) Durango
2011-2012 (WK) Grand Cherokee
NOTE: This bulletin applies to vehicles built before July 01, 2011 (MDH0701XX).
SYMPTOM/CONDITION:
Clunk and/or bump felt through the steering wheel under moderate braking or driving over
rough roads. This can be caused by spline stick/slip from the intermediate shaft.
Old Apr 5, 2016 | 05:19 PM
Crankshaft57
Thanks Dodge but my problem is on smooth freeways and with the MDS(ECO).
Auggie
Old Apr 6, 2016 | 11:58 AM
DDCREW's Avatar
DDCREW
Has your dealer/mechanic done any software updates? When I complained of shuddering when switching in-and-out of ECO, they did the following software updates: Power Control Module flash for shuddering, Steering Angle Sensor Module, and Drive Train Control Module. Unfortunately the tech didn't list any of the TSB numbers for those updates, but FCA Customer Care should be able to track them down.
I still feel the slight thump when switching in-and-out of ECO but only when going up or down a hill and adjusting the gas pedal at the same time; but there is no shudder.
Old Apr 6, 2016 | 02:47 PM
DodgeCares's Avatar
DodgeCares
Auggie
Thanks for the follow up. Per DDCREW, the PCM TSB for Shuddering is 18-035-14. At this rate, I’d recommend getting a proper diagnosis from your local servicing FCA dealer. If you need assistance, establishing an appointment, please let me know. Thanks! – Kevin T, Social Connect Team
SUBJECT:
Flash: Surge, Shudder or Pulsation at Highway Speeds
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
NOTE: This is an optional software update that should only be used in situations
where the customer is specifically complaining of the condition described
below.
MODELS:
2012 - 2013 (WK) Grand Cherokee
2012 - 2013 (WD) Durango
NOTE: This bulletin applies to vehicles equipped with a 5.7L engine (sales code
EZH).
SYMPTOM/CONDITION:
A small number of customers may experience a surge, shudder or pulsation type
sensation when driving on smooth road surfaces at highway speeds of 40-80 mph (64-129
km/h). Some customers may also describe the sensation similar to that of a fish biting on a
fishing line.
NUMBER: 18-035-14
GROUP: Vehicle Performance
DATE: July 04, 2014
where the customer is specifically complaining of the above condition. There
will be two separate software options displayed on the wiTECH flash tab. The
software file released for this SB contains the verbiage “REFERENCE SB
18-035-14. THIS FLASH TO BE USED ONLY FOR SHUDDER COMPLAINTS”.
The other file is the standard software that does not contain improvements
for this complaint. If for some reason the customer finds this shudder
improvement objectionable, the PCM software may be returned/reflashed to
the standard version.
If the customer complains of the above condition, perform the Repair Procedure.
Old Apr 6, 2016 | 04:24 PM
Crankshaft57
Hey, that sounds like my problem. Dodge & DDCREW do you guy's know if this fix would be covered under the 5yr/100000 mi Power Train Warranty ?
Auggie
Old Apr 6, 2016 | 04:59 PM
mprtech's Avatar
mprtech
PCM flashes are covered under the extended emissions warranty.
