3rd Gen Durango 2011+ models
"Help" My Fuel Door won't open
Old Dec 30, 2017 | 11:41 PM
  #21
Jendressel3's Avatar
Jendressel3
Default Fuel door wont open
I have this same problem with my 2915 DD I just bought. HELP!!!
Originally Posted by DodgeCares
Hey St.Char,
As one of the other posters said, it looks like you're still within the basic 3 year, 36K mile warranty. I'd be happy to help you make an appointment or follow up with your dealership!
Kori
Dodge Social Care Specialist
Old Jan 3, 2018 | 03:46 PM
  #22
oharag's Avatar
oharag
Originally Posted by St.Char
2015 RT...Did a search on this issue and didn't find anything. The fuel door seems to have a problem opening. When I push the inside button, I can hear the actuator working, but the door won't open. After applying a little pressure on it while adjusting it's position from the outside, it finally opened. The fuel door seems rather loose and I have noticed this becoming more obvious recently. Almost seems like it needs to be somehow tightened up. Anyone have a fix for this issue. Thx.
BTW... has anyone ever removed the fuel door? It feels like there is a lever inside the door on the left that might release it. I might be able to make an adjustment if i can remove it.
I posted something to this site about a year ago, I had this issue happen last year. I believe it was somewhat cold. Hasn't happened since. Is it a reoccurring problem?? It would definitely suck if it happened in the middle of no where and you need fuel.
DodgeCares, what is a STAR case, S1708000003? I'm taking my Durango into dealer soon for other reasons and wouldn't mind they look into this - especially if there is documentation on issue/fix.
Old Jan 3, 2018 | 04:03 PM
  #23
DodgeCares's Avatar
DodgeCares
Hi oharag,
As my colleague stated above a STAR case is created when our corporate engineers have been involved with diagnosing a customer's vehicle, this case can then serve as guidelines for other dealerships when diagnosing a similar issue. STAR cases do not apply to all vehicles, if you would like to send us a PM with your VIN I'd be happy to check if this case applies to your vehicle.
Andrea
Old Jan 3, 2018 | 07:54 PM
  #24
Jendressel3
My 2915 I just got is still doing it and it SUCKS
Old May 24, 2018 | 01:30 PM
  #25
sftbllmum38's Avatar
sftbllmum38
Angry
I have a 2014 Durango, just out of warranty, and had this same thing start happening. Dealership wants to charge me over $600, for the "KIT" and will have to repaint the door. What other options are available? I feel if this is a common occurrence and has a STAR, this should be on a recall.
Frustrated owner
Old May 24, 2018 | 02:17 PM
  #26
oharag's Avatar
oharag
BTW
My door was fixed after a $100 deductible. I have extended warranty + Max Care for life. I will keep you posted if the fuel door starts failing again. It usually seems to be an issue during cold weather. Fuel door works like a charm now.
Old May 29, 2018 | 08:26 AM
  #27
DodgeCares's Avatar
DodgeCares
Frustrated owner
Hello sftbllmum38,
We're sorry to hear you're having trouble with your Durango. Send us a direct message with your VIN as we'd be glad to check it for any open recalls related to this concern.
Jasmine
Old Aug 2, 2018 | 10:04 PM
  #28
Senpro's Avatar
Senpro
We had our 2015 fuel door assembly replaced under warranty. Same problem, it wouldn't open.
Old Aug 22, 2018 | 10:49 AM
  #29
superpete's Avatar
superpete
Here is my fuel door fix video, Hope it helps.
Also in the video I show how to manually open fuel door if button don't work, hope it helps.
Old Jan 26, 2019 | 06:20 PM
  #30
mystic106's Avatar
mystic106
Default Fuel Door won’t open - 2015 Durango
Hi Firstdodge2016,
There does appear to be a STAR case, S1708000003, that involves looking at the fuel door housing and hinge, that may be applicable to your vehicle. If you need me to follow up with the dealership for you, please send me a PM.
Kori
My fuel door is getting stuck too!
Can you help?
2015 Dodge Durango
