3rd Gen Durango 2011+ models
2015 rear lift gate won't latch
Old Jan 15, 2018 | 09:06 PM
Papajohn63's Avatar
Papajohn63
Default 2015 rear lift gate won't latch
My 2015 Durango developed an issue where the rear lift gate wont latch when it closes. I have disconnected the battery so the lights won't stay on and the actuator won't keep trying to close the door. Any ideas as to what is causing this problem?
Old Jan 16, 2018 | 09:38 AM
Prospect62's Avatar
Prospect62
If you determine that nothing is obstructing the gate from closing, it may just need the "tailgate module" flashed.
My 2011 was exhibiting similar symptoms and doing all sorts of wacky things, but basically it would never pull itself closed all the way when closing by itself. The dealer flashed the tailgate module and all was well. It still surprises me to this day how a module needing an update can mimic a purely mechanical problem. Oh well. Something to consider if you do go to the dealer, ask for them to try that first. I think they charge about a half hour labor to do a "flash" ($35.00) but some dealers will do it at no cost of you have them do it with an oil change or something.
In the meantime, you can push it closed firmly so you're light doesn't stay on.
Old Jan 17, 2018 | 07:36 AM
coldsteel's Avatar
coldsteel
I had this happen, 1x so I pulled the fuse from the box under the hood and it reset and then latched normally from then on.
Old Dec 5, 2022 | 02:59 PM
DurangoDEE's Avatar
DurangoDEE
DID YOU EVER FIGURE OUT THE PROBLEM ? I am having he same issure
Old Feb 4, 2023 | 09:45 AM
DonMorg's Avatar
DonMorg
what fuse did you pull exactly ? I think I pulled them all in the engine bay and still doesn’t latch.
