3rd Gen Durango 2011+ models
Tpms
Old Feb 14, 2018 | 05:00 PM
Rangored's Avatar
Rangored
Default Tpms
Having a problem with my TPMS light. Light flashes on start then stays on. Had it at my local dealer five times. Matter of fact it was in today. Called the service manager and he assured me it was fixed. Half way home, guess who's back, the light. Anybody having or had this issue. I was told the TPMS module was replaced and programed. The info center shows no message and all tire pressures are being monitored correctly from the tires. Thanks for any feedback.
Old Feb 14, 2018 | 11:46 PM
SHO Rod's Avatar
SHO Rod
What model year is your Durango? Have you tried adjusting the tire pressures and checking the info center to make sure the readings are updating correctly? Are the tires properly inflated per the driver's door placard?
-Rod
Old Feb 15, 2018 | 09:07 AM
Rangored's Avatar
Rangored
Year 2012. Tires inflated correctly. Info center reading correct pressure. No message comes up on info center.
Old Feb 16, 2018 | 09:00 AM
DodgeCares's Avatar
DodgeCares
Hello Rangored,
We're sorry to hear about the ongoing concern you're experiencing with your Ram. If you'd like, we can certainly get this over to a Case Specialist to work with you and the dealership toward a solution. Please send us a direct message if this is of interest.
Jasmine
Dodge Social Care Specialist
Old Mar 28, 2018 | 09:35 AM
alth3655's Avatar
alth3655
My TPMS comes up, then about 5 other sensor messages come up after it. Happens periodically every 5 mins or so, especially after hitting a bump. Sometimes it will go crazy and my thermostat will read -40 and work its way back up to reading the outside temp. After it cycles through everything even my seat belt sensor will go off when I have my seat belt on.
Anyone have any clues here?
