3rd Gen Durango 2011+ models
Cracking Shift Bezel
Old May 7, 2018 | 03:45 PM
SteelSteve's Avatar
SteelSteve
Default Cracking Shift Bezel
Can't seem to find anything on this, so thought I'd ask. After about a year I noticed several cracks in the shifter bezel starting from under the chrome trim peace that surrounds the bezel and running inward toward the shifter. Since the car / truck was still under warranty I had my local dealer replace the part and all was well, until now. When I got in the car to head to work this morning I noticed a crack in my bezel. Is this a known or on going issue with these vehicles? I try to take care of my cars and don't abuse them, and have no young kids so I can't believe it's something I'm doing. I haven't priced out the cost of new one (car no longer under warranty), but I'd hate to have to buy and replace this ever few years.
Old May 7, 2018 | 06:31 PM
SHO Rod's Avatar
SHO Rod
What year is your Durango? Could you (and would you) upload a photo showing the issue you are experiencing?
-Rod
Old May 8, 2018 | 07:44 AM
SteelSteve's Avatar
SteelSteve
It's a 2013 Crew AWD.
So far there is only one, and it is at the bottom of the bezel. Unfortunately this is what happened last time so I expect others will show up all around the bezel.
Old May 9, 2018 | 02:18 PM
SHO Rod's Avatar
SHO Rod
Hmm, interesting. I'm not sure what would cause that. My former 2011 Durango at 104k miles didn't have any issues there, although I had the transfer case shift dial in place of the little cubby. I suspect the bezel itself was similar. If you've had two of these crack in the same area, I wonder if there is something wrong with the console that is putting too much pressure in that area of thin material.
-Rod
Old May 10, 2018 | 01:13 PM
DDCREW's Avatar
DDCREW
I have a 2013 Crew purchased in November 2012 and have no issues with cracks in the shifter bezel. SHO Rod has a point in that something else in the console assembly may be applying stress on the bezel causing it to crack.
