3rd Gen Durango 2011+ models
P0300, p0131, p0172
Old May 14, 2018 | 01:06 PM
jawilly20's Avatar
jawilly20
Default P0300, p0131, p0172
2011 Durango w/3.6L, misfire counter shows misfire on cyl. 1, 3, & 5. At start up it runs fine, shortly after it runs very rough.
Old May 14, 2018 | 02:15 PM
What steps have you taken thus far to troubleshoot?
Old May 14, 2018 | 02:32 PM
jawilly20's Avatar
jawilly20
Default Troubleshooting
I've monitored the misfire counter and also watched the O2 voltages. Seems like 1/1 isn't switching all the time. Actually only when throttle is applied. Also the exhaust smells of sulfur and at idle an tone will come on and the CEL will then blink, after a bit it repeats and goes solid. I can't seem to find a correct firing order for this engine. I doubt my scan tool would switch the banks but it seems like the symptoms of the 2-4-6 cyl misfire head replacement issue.
Old May 16, 2018 | 07:38 AM
XCELLR8's Avatar
XCELLR8
Flip the O2 sensors and see if the problem follows.
Old May 16, 2018 | 11:06 AM
jawilly20's Avatar
jawilly20
Default O2 swap
After poking around some more I noticed there was oil on the 1/1 sensor. I've tracked it down to the PCV leaking at the rear of the passenger side valve cover. I've resealed that (major PITA) and will install a new O2 today. Also a PITA, they only wanted tiny hands Rob Lowe working back there.
Old May 16, 2018 | 08:07 PM
jawilly20's Avatar
jawilly20
Default Bad O2
Well the O2 was bad. A new one has cleared up all the issues. The PCV leak was likely the culprit.
Old May 17, 2018 | 08:04 AM
SHO Rod's Avatar
SHO Rod
Good find, and thank you for the follow-up on what it took to repair.
-Rod
